Using Xmodem
After the hardware connections mentioned above, power on the VisionFive and you will see the
startup information as follows.
Figure 1. Startup Information Example
Press any key as soon as it starts up to enter the upgrade menu.
In this menu, you can only update u-boot.
Figure 2. Update Uboot
Type root@s5t and press Enter to enter
the extended version of the upgrade menu. In this menu, you can update u-boot, bootloader,
and ddr init.
Figure 3. Example Output
- Type 0 and press Enter to update the bootloader.
Navigate to and choose the
.outfile from the .zip file we downloaded before:bootloader-JH7100-211102.bin.out. -
Repeat the Step 4 and 5 to update the ddr init as well according to the
following:
Type 1 - update ddr init [Filename: ddrinit-2133-211102.bin.out]
Repeat the Step 4 and 5 to update the u-boot as well according to the
following:
Type 2 - update u-boot [Filename: fw_payload.bin.out]
