Compiling ddr init
To compile ddr init, perform the following:
Clone the repo from GitHub.
git clone https://github.com/starfive-tech/JH7100_ddrinit.git -
Go into build directory.
cd JH7100_ddrinit/build -
Compile ddr init.
makeResult:
You will see the following output if the compilation is successful.
Figure 1. Example Output
Tip:Refer to Appendix B: Updating Firmware and u-boot section in VisionFive Single Board Computer Quick Start Guide to flash bootloader and ddr init.
