Making File System
Follow the following steps to make the file system.
Create the directory structure.
mkdir rootfs cd rootfs mkdir dev usr bin sbin lib etc proc tmp sys var root mnt -
Download the busybox source code outside the rootfs directory.
git clone https://git.busybox.net/busybox -
Navigate to the extracted location and enter busybox configuration.
cd busybox make CROSS_COMPILE=riscv64-linux-gnu- ARCH=riscv menuconfigFigure 1. Busybox Configuration
- Navigate to and check Build static binary (no shared libs) by pressing Y.
Under Build Options, select cross compiler prefix and type the following to specify the
compiler.
riscv64-linux-gnu- -
Under Installation Options > Destination path for
make install, change the path to the path of the rootfs file directory (this is the installation location of the compiled busybox).Example:/home/user/rootfs - Exit from the busybox configuration window and save the configuration.
Compile busybox.
make ARCH=riscv -
Install busybox.
make install -
Navigate to the rootfs/etc directory created before, create a file called inittab and
open it using vim text editor.
cd rootfs/etc vim inittab -
Copy and paste the following content inside the
inittabfile.::sysinit:/etc/init.d/rcS ::respawn:-/bin/login ::restart:/sbin/init ::ctrlaltdel:/sbin/reboot ::shutdown:/bin/umount -a -r ::shutdown:/sbin/swapoff -a -
Create a file called profile inside rootfs/etc and open it using
vim text editor.
vim profile -
Copy and paste the following content inside the profile file.
# /etc/profile: system-wide .profile file for the Bourne shells echo #echo -n "Processing /etc/profile... " # no-op # Set search library path #echo "Set search library path in /etc/profile" export LD_LIBRARY_PATH=/lib:/usr/lib # Set user path #echo "Set user path in /etc/profile" PATH=/bin:/sbin:/usr/bin:/usr/sbin export PATH # Set PS1 #Note: In addition to the SHELL variable, ash supports \u, \h, \W, \$, \!, \n, \w, \nnn (octal numbers corresponding to ASCII characters) #And \e[xx;xxm (color effects), etc. #Also add an extra '\' in front of it! #echo "Set PS1 in /etc/profile" export PS1="\\e[00;32m[$USER@\\w\\a]\\$\\e[00;34m" #echo "Done" -
Create a file called fstab inside rootfs/etc
and open it using vim text editor.
vim fstab -
Copy and paste the following content inside the fstab file.
proc /proc proc defaults 0 0 none /tmp tmpfs defaults 0 0 mdev /dev tmpfs defaults 0 0 sysfs /sys sysfs defaults 0 0 -
Create a file called passwd inside rootfs/etc and open it using
vim text editor.
vim passwd -
Copy and paste the following content inside the passwd file.
root:x:0:0:root:/root:/bin/sh -
Create a file called group inside rootfs/etc and open it using vim
text editor.
vim group -
Copy and paste the following content inside the group file.
root:x:0:root -
Create a file called shadow inside rootfs/etc and open it using
vim text editor.
vim shadow -
Copy and paste the following content inside the shadow file.
root:BAy5qvelNWKns:1:0:99999:7::: -
Create a directory called init.d inside
rootfs/etc and navigate inside it.
mkdir init.d cd init.d -
Create a file called rcS inside rootfs/etc/init.d and open it using vim text editor.
vim rcS -
Copy and paste the following content inside the rcS file.
#! /bin/sh #echo "----------mount all" /bin/mount -a #echo "----------Starting mdev......" #/bin/echo /sbin/mdev > /proc/sys/kernel/hotplug mdev -s echo "********************************************************" echo " starfive mini RISC-V Rootfs" echo "********************************************************" -
Navigate to the
rootfs/devdirectory created before and execute the following.1 cd rootfs/dev 2 sudo mknod -m 666 console c 5 1 3 sudo mknod -m 666 null c 1 3 -
Create a soft link in the root directory of rootfs.
1 cd rootfs/ 2 ln -s bin/busybox init -
Modify the permissions of all files in the rootfs directory.
sudo chmod 777 -R * -
Execute the following command in the rootfs directory to generate rootfs.cpio.gz (cpio
file system package) in a different directory.
1 cd rootfs 2 find . | cpio -o -H newc | gzip > /home/user/Desktop/rootfs.cpio.gzNote: After you successfully run the command above, you will see a file named rootfs.cpio.gz on your Desktop. This directory can be any directory you want. If your CPU has 8 cores, change this to -j8. This process will take some time and therefore please wait patiently.
