GPIO Pinout
The following table describes the GPIO pinout, the map, and the explanation of what each pin can do.
| Sys | dts | GPIO Num | Pin Name | Pin Num | Pin Num | Pin Name | GPIO Num | dts | Sys |
| N/A | +3.3V | 1 | 2 | +5V | N/A | ||||
| i2c-0 | i2c0 | 58 | GPIO58 (I2C SDA) | 3 | 4 | +5V | N/A | ||
| i2c-0 | i2c0 | 57 | GPIO57 (I2C SCL) | 5 | 6 | GND | N/A | ||
| 55 | 55 | GPIO55 | 7 | 8 | GPIO5 (UART TX) | 5 | uart0 | ttyS0 | |
| N/A | GND | 9 | 10 | GPIO6 (UART RX) | 6 | uart0 | ttyS0 | ||
| 42 | 42 | GPIO42 | 11 | 12 | GPIO38 | 38 | 38 | ||
| 43 | 43 | GPIO43 | 13 | 14 | GND | N/A | |||
| 47 | 47 | GPIO47 | 15 | 16 | GPIO54 | 54 | 54 | ||
| N/A | +3.3V | 17 | 18 | GPIO51 | 51 | 51 | |||
| spidev1.0 | spi0 | 52 | GPIO52 (SPI MOSI) | 19 | 20 | GND | N/A | ||
| spidev1.0 | spi0 | 53 | GPIO53 (SPI MISO) | 21 | 22 | GPIO50 | 50 | 50 | |
| spidev1.0 | spi0 | 48 | GPIO48 (SPI SCLK) | 23 | 24 | GPIO49 (SPI CE0) | 49 | spi0 | spidev1.0 |
| N/A | GND | 25 | 26 | GPIO56 | 56 | 56 | |||
| 45 | 45 | GPIO45 | 27 | 28 | GPIO40 | 40 | 40 | ||
| 37 | 37 | GPIO37 | 29 | 30 | GND | N/A | |||
| 39 | 39 | GPIO39 | 31 | 32 | GPIO46 (PWM0) | 49 | pwm0 | ||
| pwm1 | 59 | GPIO59 (PWM1) | 33 | 34 | GND | N/A | |||
| 63 | 63 | GPIO63 | 35 | 36 | GPIO36 | 36 | 36 | ||
| 60 | 60 | GPIO60 | 37 | 38 | GPIO61 | 61 | 61 | ||
| N/A | GND | 39 | 40 | GPIO44 | 44 | 44 |
Note:
- The dts column shows the name of the node in the DTSI file (jh7110-visionfive-v2.dtsi). You can find the associated node by simply searching the name.
- The Sys column shows the pin number used when exporting the GPIO pin under the /sys/class/gpio.
