Demo Source Code
buzzer.py:
''' Please make sure the buzzer is connected to the correct pins. The following table describes how to connect the buzzer to the 40-pin header. ----------------------------------------- Passive Buzzer___Pin Number_____Pin Name VCC 1 3.3V Power GND 6 GND I/O 18 GPIO51 ----------------------------------------- ''' import VisionFive.gpio as GPIO import time buzz_pin = 18 ErrOutOfRange = 0 def setup(): #Configure the direction of buzz_pin as out. GPIO.setup(buzz_pin, GPIO.OUT) #Configure the voltage level of buzz_pin as high. GPIO.output(buzz_pin, GPIO.HIGH) def pitch_in_check(): val_in = input('Enter Pitch (200 to 20000): ') val = float(val_in) if 200 <= val <= 20000: return val else: print('The input data is out of range (200 to 20,000 Hz). Please re-enter.') return ErrOutOfRange def loop(pitch, cycle): delay = 1.0 / pitch cycle = int((cycle * pitch)/2) #Buzzer beeps. while cycle >= 0: GPIO.output(buzz_pin, GPIO.LOW) time.sleep(delay) GPIO.output(buzz_pin, GPIO.HIGH) time.sleep(delay) cycle = cycle - 1 def destroy(): GPIO.output(buzz_pin, GPIO.HIGH) GPIO.cleanup() if __name__ == '__main__': setup() try: #Input value of pitch (200 to 20,000 Hz). pitch = pitch_in_check() while pitch == 0: pitch = pitch_in_check() #Input value of cycle time (seconds). cycle_in = input("Enter Cycle (seconds): ") cycle = int(cycle_in) #The buzzer beeps with the specified pitch and cycle. loop(pitch, cycle) finally: destroy()
