Running Demo Code
  1. Locate to the directory where the code, buzzer.py, exists:
    1. Source into the Python3 Virtual Environment:
      source ./myvenv/bin/activate
    2. Execute the following command to install dependency:
      python3 -m pip install pillow
    3. Execute the following command to get the directory where VisionFive.gpio exists:
      Note:
    4. Execute the following to enter the directory, for example, /home/user/myvenv/lib/python3.11/site-packages as indicated in the previous step output:
    5. Execute the following command to enter the sample-code directory:
      cd ./VisionFive/sample-code/
  2. Under the sample-code directory, execute the following command:
    sudo python buzzer.py
    sudo python3 buzzer.py
  3. Enter the values as prompted to configure the pitch and the lasting time of the beeps as prompted:
    • Enter Pitch (200 to 20000): The frequency (Range: 200 to 20,000) of the buzzer. Unit: Hz. For example, 400.
      Note: If the value is out of the range (200 to 20,000 Hz) , a warning message will display, and you need to re-enter the pitch value.
    • Enter Cycle (seconds): The time in seconds when the buzzer keeps beeping. For example, 100.
    Example:
    [riscv@fedora-starfive sample-code]$ sudo python3 buzzer.py
    Enter Pitch (200 to 20000): 400
    Enter Cycle (seconds): 100
    The buzzer keeps beeping for 100 seconds at 400 Hz.
  4. (Optional) Exit the Python3 Virtual Environment.
    deactivate
