Running Demo Code
  1. Locate to the directory where the test code, pwm_led.py, exists:
    1. Source into the Python3 Virtual Environment:
      source ./myvenv/bin/activate
    2. Execute the following command to install dependency:
      python3 -m pip install pillow
    3. Execute the following command to get the directory where VisionFive.gpio exists:
      Note:
    4. Execute the following to enter the directory, for example, /home/user/myvenv/lib/python3.11/site-packages as indicated in the previous step output:
    5. Execute the following command to enter the sample-code directory:
      cd ./VisionFive/sample-code/
  2. Under the sample-code directory, execute the following command to execute the demo code:
    sudo python pwm_led.py
    sudo python3 pwm_led.py
    The LED blinks and the blink frequency will change according to the PWM frequency.
  3. (Optional) Exit the Python3 Virtual Environment.
    deactivate
