Audio Soft Encoding
The topic provides examples for soft encoding an audio file.
The following code block shows the example in different scenarios.
- Soft-encode a RAW PCM file to WAV:
ffmpeg -f s32le -ac 2 -ar 16000 -i output-test1-16k-32b.pcm -acodec pcm_s32le output-test1-16k-32b.wav
- Soft-encode a RAW PCM file to AAC:
ffmpeg -f s32le -ac 2 -ar 16000 -i output-test1-16k-32b.pcm output-test1-16k-32b.aac
- Soft-encode a RAW PCM file to MP3:
ffmpeg -f s32le -ac 2 -ar 16000 -i output-test1-16k-32b.pcm output-test1-16k-32b.mp3
