env_get
- Synopsis:
char *env_get(const char *varname);
- Description: The interface is used to get the value of an environment variable.
- Parameter:
- varname: The environment variable you want to get value from.
- Return:
- Success: Value of the target environment variable, or "NULL" if the environment variable is not found.
- Failure: Any other values.
