int env_set
- Synopsis:
int env_set(const char *varname, const char *value);
- Description: The interface is used to set an environment variable.
- Parameter:
- varname: The environment variable you want to change.
- varvalue: The new value of the environment variable.
- Return:
- Success: 0.
- Failure: 1.
