During the use of VisionFive
2, avoid
contact with hard objects that may cause damage. Thus, StarFive recommends that you
use spacers for the following NPTHs (Non Plating Through Hole):
Figure 3. NPTHs on VisionFive
2
For spacers, StarFive
strongly recommends that you use the copper columns or studs with the
following specifications:
Single head hexagonal copper columns (Size: M2.5*10+6mm)Figure 4. Single Head Hexagonal Copper Columns
Double way hexagon copper studs (Size: M2.5*4)Figure 5. Double Way Hexagon Copper Studs
