This document mainly provides the users with the features and technical specifications for StarFive next generation single board computer - VisionFive 2.
| 1.53 | 2023/4/28 | Updated the note type as warning in Mechanical Specification. |
| 1.52 | 2023/3/18 | Added the note that the USB Type C port is used for power supply only. |
| 1.51 | 2023/2/22 | Revised the pin definition for MIP DSI. |
| 1.5 | 2023/2/17 | Added new sections: |
| 1.41 | 2023/2/2 | Removed the power consumption specification. The data only applied to limited conditions and might be modified after internal ATE test. |
| 1.4 | 2023/1/16 | Added power consumption specification. |
| 1.3 | 2022/12/8 | Added a note about using spacers in Mechanical Specification. Updated the dimensions. |
| 1.2 | 2022/10/20 |
| 1.1 | 2022/09/08 |
| 1.0 | 2022/09/05 | The first release. |
