Access PHY via MIDO Command
You need to access the Ethernet PHY using the MDIO command.
The following image shows a list of the Ethernet PHYs, each with a corresponding command
to access the PHY. Figure 1. MIDO Commands
You can use the above command to examine whether the PHY is ready on your board for data communication.
