After you have added the new Ethernet driver, when you access U-Boot in the second time,
you will see the following screen. Figure 1. Ethernet Driver Verification
The above highlighted information shows that the SoC support for the interface is ready
for use, however, we still need to verify the data communication in case the data is
blocked in the PHY.
