The following image shows the U-Boot source code file directory for JH7110. Figure 1. U-Boot Source Code Structure
The following list provides an introduction for some of the above folders.
board: The board folder contains all the board-specific
files, including the files for StarFiveJH7110 and the files for VisionFive 2, etc.
arch: The core-specific folder which contains all the core
initialization files. The files are not board-independent; thus, you don’t need to
modify anything in this folder.
driver: The folder includes all the drivers supported by
U-Boot, including the Ethernet driver, the PHY driver, the USB driver, and so on.
net: The folder contains all the upper-layer protocols
support in U-Boot, including the ping, the tftp,
the icmp, and other protocols.
cmd: The folder includes all the commands supported by
U-Boot.
configs: The folder includes all the deconfiguration files,
each file related to a special board.
scripts: The folder includes the rule files which used for
compilation.
