Device Tree Configuration
Overview
A DTS/DTSI file is used to store all the device tree configuration.
The device tree of JH7110 is stored in the following path:
linux-5.10/arch/riscv/boot/dts/starfive/
The following code block shows the DTS file structure for JH7110.
linux-5.15.0
└-- arch
└-- | -- riscv
| -- | -- | -- boot
| -- | -- | -- | -- dts
| -- | -- | -- | -- | -- starfive
| -- | -- | -- | -- | -- | -- jh7110-common.dtsi
| -- | -- | -- | -- | -- | -- jh7110.dtsi
Display Subsystem
In the file jh7110.dtsi, you can find the device tree configuration of the display subsystem as the following code block:
display: display-subsystem {
        compatible = "startive,jh7110-display","verisilicon,display-subsystem";
        ports = <&dc_out_dpi0>;
        status = "disabled";
dssctrl: dssctrl@295B0000 {
        compatible = "starfive,jh7110-dssctrl","verisilicon,dss-ctrl", "syscon";
        reg = <0 0X295B0000 0 0x90>;
The following list provides explanations for the parameters included in the above code block.
  • compatible: Compatibility information, used to associate the display controller and its target device.
  • ports: The port(s) used by the display controller.
  • status: The work status of the display controller module. To enable the module, set this bit as "okay" or to disable the module, set this bit as "disabled".
  • reg: Register base address "0X295B0000" and range "0x90".
DC8200
In the file jh7110.dtsi, you can find the device tree configuration of DC8200 (host) as the following code block:
dc8200: dc8200@29400000 {
        compatible = "verisilicon,dc8200";
        verisilicon,dss-syscon = <&dssctrl>;
        reg = <0x0 0x29400000 0x0 0x100>,
              <0x0 0x29400800 0x0 0x2000>,
              <0x0 0x17030000 0x0 0x1000>;
        interrupts = <95>;
        clocks = <&clkgen JH7110_NOC_BUS_CLK_CPU_AXI>,
                 <&clkgen JH7110_NOC_BUS_CLK_AXICFG0_AXI>,
                 <&clkgen JH7110_NOC_BUS_CLK_GPU_AXI>,
                 <&clkgen JH7110_NOC_BUS_CLK_VDEC_AXI>,
                 <&clkgen JH7110_NOC_BUS_CLK_VENC_AXI>,
                 <&clkgen JH7110_NOC_BUS_CLK_DISP_AXI>,
                 <&clkgen JH7110_NOC_BUS_CLK_ISP_AXI>,
                 <&clkgen JH7110_NOC_BUS_CLK_STG_AXI>,
                 <&clkgen JH7110_VOUT_SRC>,
                 <&clkgen JH7110_VOUT_TOP_CLK_VOUT_AXI>,
                 <&clkgen JH7110_AHB1>,
                 <&clkgen JH7110_VOUT_TOP_CLK_VOUT_AHB>,
                 <&clkgen JH7110_VOUT_TOP_CLK_HDMITX0_MCLK>,
                 <&clkgen JH7110_I2STX_4CH0_BCLK_MST>,
                 <&clkvout JH7110_U0_DC8200_CLK_PIX0>,
                 <&clkvout JH7110_U0_DC8200_CLK_PIX1>,
                 <&clkvout JH7110_U0_DC8200_CLK_AXI>,
                 <&clkvout JH7110_U0_DC8200_CLK_CORE>,
                 <&clkvout JH7110_U0_DC8200_CLK_AHB>,
                 <&clkvout JH7110_DOM_VOUT_TOP_LCD_CLK>,
                 <&hdmitx0_pixelclk>,
                 <&clkvout JH7110_DC8200_PIX0>,
                 <&clkvout JH7110_U0_DC8200_CLK_PIX0_OUT>,
                 <&clkvout JH7110_U0_DC8200_CLK_PIX1_OUT>;
        clock-names = "noc_cpu","noc_cfg0","noc_gpu","noc_vdec","noc_venc",
                      "noc_disp","noc_isp","noc_stg","vout_src",
                      "top_vout_axi","ahb1","top_vout_ahb",
                      "top_vout_hdmiTX0","i2stx","pix_clk","vout_pix1",
                      "axi_clk","core_clk","vout_ahb",
                      "vout_top_axi","vout_top_lcd","hdmitx0_pixelclk","dc8200_pix0",
                      "dc8200_pix0_out","dc8200_pix1_out";
        resets = <&rstgen RSTN_U0_DOM_VOUT_TOP_SRC>,
                 <&rstgen RSTN_U0_DC8200_AXI>,
                 <&rstgen RSTN_U0_DC8200_AHB>,
                 <&rstgen RSTN_U0_DC8200_CORE>,
                 <&rstgen RSTN_U0_NOC_BUS_CPU_AXI_N>,
                 <&rstgen RSTN_U0_NOC_BUS_AXICFG0_AXI_N>,
                 <&rstgen RSTN_U0_NOC_BUS_APB_BUS_N>,
                 <&rstgen RSTN_U0_NOC_BUS_DISP_AXI_N>,
                 <&rstgen RSTN_U0_NOC_BUS_STG_AXI_N>;
        reset-names = "rst_vout_src","rst_axi","rst_ahb","rst_core",
                      "rst_noc_cpu","rst_noc_axicfg0","rst_noc_apb",
                      "rst_noc_disp","rst_noc_stg";
        power-domains = <&pwrc JH7110_PD_VOUT>;
  • dss-syscon: The SYSCON register(s) of the display panel.
  • reg: Register base address "0x29400000" and range "0x100".
  • interrupts: Hardware interrupt ID.
  • clocks: The clocks used by the display controller module.
  • clock-names: The names of the above clocks.
  • resets: The reset signals used by the display controller module.
  • reset-names: The names of the above reset signals.
  • power-domains: The power supply domain of the display controller module.
In the file jh7110-common.dtsi, you can find the device tree configuration of DC8200 (endpoint) as the following code block:
&dc8200 {
	status = "okay";
	dc_out: port {
		#address-cells = <1>;
		#size-cells = <0>;
		dc_out_dpi0: endpoint@0 {
			reg = <0>;
			remote-endpoint = <&hdmi_input0>;
		dc_out_dpi1: endpoint@1 {
			reg = <1>;
			remote-endpoint = <&hdmi_in_lcdc>;
		dc_out_dpi2: endpoint@2 {
			reg = <2>;
			remote-endpoint = <&mipi_in>;
  • reg: The register ID of the endpoint device.
  • remote-endpoint: The endpoint device type of the display controller output.
