Enabling I2S on VisionFive 2
Follow the steps below to enable I2S in the board.dts file for VisionFive 2 SBC.
  1. Locate the correct board level configuration file (jh7110-visionfive-v2-wm8960.dts and jh7110-visionfive-v2-ac108.dts).
  2. Locate the nodes of i2srx_3ch and i2stx_4ch1.
  3. Modify the status parameter to okay.
    The following code block shows an example configuration.
    &i2srx_3ch {
            status = "okay";
    &i2stx_4ch1 {
            status = "okay";
  4. Save and exit.
