Kernel Menu Configuration
Follow the steps below to enable the kernel configuration for I2S.
- Under the root directory of
freelight-u-sdk, type the following command to
enter the kernel menu configuration GUI.
make linux-menuconfig
- Enter the Device Drivers menu.
- Select the Sound Card Support option and enter the next level.
- Select the Advanced Linux Sound Architecture option and enter the next level.
- Select the ALAS for SoC audio support option and enter the next level.
- Select the Synopsys I2S Device Driver option and in the next level, select the I2S driver for JH7110.
- Enter the CODEC Drivers menu.
- Select the AC108 option on top of the list.
- Go down and select the WM8960 CODEC option.
- Save your change before you exit the kernel configuration dialog.
