STFLIB_ISP_SENSOR_GetSensorId
Get sensor ID from sensor name.
STFLIB_ISP_SENSOR_GetSensorId(
    const STF_CHAR *pszSensorName
Table 1. STFLIB_ISP_SENSOR_GetSensorId Parameter Description
pszSensorName Sensor name Input
Table 2. STFLIB_ISP_SENSOR_GetSensorId Return Description
Return Description
STF_S8 Return positive identifier or negative number if sensor cannot be found
The files libSensorapi.a and libISPC.a are required for using this API.
