STFLIB_ISP_SENSOR_SturctInitialize
Initialize a ST_SENSOR structure.
STFLIB_ISP_SENSOR_SturctInitialize(
    ST_SENSOR *pstSensor,
    STF_U8 u8SensorId,
    STF_U8 u8Index
Table 1. STFLIB_ISP_SENSOR_SturctInitialize Parameter Description
pstSensor Sensor handle Input/Output
u8SensorId Sensor ID Input
u8Index Sensor setting index. No longer in use Input
Table 2. STFLIB_ISP_SENSOR_SturctInitialize Return Description
Return Description
0 Success
Other values Failure
The files libSensorapi.a and libISPC.a are required for using this API.
