STFLIB_ISP_SENSOR_SturctUninitialize
De-initialize a ST_SENSOR structure.
STFLIB_ISP_SENSOR_SturctUninitialize(
    ST_SENSOR *pstSensor,
The API has the following parameter.
Table 1. STFLIB_ISP_SENSOR_SturctUninitialize Parameter Description
pstSensor Sensor handle Input/Output
Table 2. STFLIB_ISP_SENSOR_SturctUninitialize Return Description
Return Description
0 Success
Other values Failure
The files libSensorapi.a and libISPC.a are required for using this API.
