Setting the Over-Heat Threshold to Avoid Automatic Shut-Down
You can avoid automatic shut-down by modifying the over-heat temperature threshold of the cpu@crit node to a greater value. Follow the example below:
cpu_trips: trips{
    cpu_crit: cpu_crit@0 {
    temperature = <110000>;
    type = "critical";
    hyste-resis = <0>;
When a PMIC is used, you may need to switch off the PMIC in advance. See the following example:
pmu0: pmu@0{
overtemp_shutdown = <1>;   //Overtemp protection, 0 means shutdown
overtemp_value = <145>;    //Overtemp protection temperature
