For Windows
- Open Tera Term software.
- Navigate to .
Configure the settings as follows.
- Port: COM4 (choose your COM port)
- Speed: 9600
Note: The Speed value is 9600. This setting is for recovering the bootloader, ddr init, and u-boot of QSPI Flash. - Click on New open.
Press the BOOT button while turning on VisionFive.
Figure 1. Pressing the Boot Button
You will see the following output on Tera Term.
(C) SiFive
Type the following.
load 0x18000000Result: You will see an output like this:Figure 2. Example Output
Navigate to and choose the following file we downloaded before:
JH7100_recovery_boot.bin.
You will see an output like this after the transfer is complete.
Load file ok. -
Type the following.:
do 0x18000000Result:You will see an output like this:
Figure 3. Example Output
- Type 0 and press Enter to update the bootloader.
- Navigate to and choose the following file from the .zip file we downloaded before: bootloader-JH7100-211102.bin.out
Repeat the steps 10 to 11 to update the ddr init according to the
following.
- Type 1 - update ddr init [Filename: ddrinit-2133-211102.bin.out]
