Compiling the u-boot
Follow the steps below to compile the u-boot for VisionFive.
Locate to your desired directory to store the u-boot files. For example, the home
directory.
Example:
cd ~ # home directory -
Download the source code for u-boot compilation.
git clone https://github.com/starfive-tech/u-boot -
Switch to the code branch by executing the following command:
cd u-boot git checkout -b JH7100_upstream origin/JH7100_upstream git pull -
Type the following to compile u-boot under the u-boot directory.
make <Configuration_File> ARCH=riscv CROSS_COMPILE=riscv64-linux-gnu- make u-boot.bin u-boot.dtb ARCH=riscv CROSS_COMPILE=riscv64-linux-gnu-Tip:Configuration_File:
- For VisionFive, the file is starfive_jh7100_visionfive_smode_defconfig.
- For Starlight, the file is starfive_jh7100_starlight_smode_defconfig.
Result:There will be these 2 files generated after compilation inside the u-boot directory: u-boot.bin and u-boot.dtb.
Figure - Example Output
Tip: Both u-boot.dtb and u-boot.bin will be used later for OpenSBI compilation.
