Set Up Compilation Environment
You can follow the steps below to set up your own cross-compile.
Install the riscv64-linux-gnu-gcc compiler from Ubuntu
packages.
sudo apt update sudo apt upgrade sudo apt install gcc-riscv64-linux-gnu -
Check the version of the riscv64-linux-gnu-gcc.
riscv64-linux-gnu-gcc -vThe output will be as follows:
Result:Figure 1. Example Output
