Preparing Hardware
The following table describes hardware items to be prepared if you want to configure, debug, and test this 40-pin header by following this guide:
| Type | M/O* | Item | Notes |
| General | M | VisionFive 2 single board computer | - |
| General | M |
These items are used for flashing Debian OS into a micro-SD card. |
| GPIO | O | An oscilloscope | The oscilloscope is used to verify the GPIO voltage. |
| I2C | O |
| SPI | O |
| PWM | O | An oscilloscope | The oscilloscope is used to measure the corresponding pin and check the PWM period and duty cycle. |
| SPI LCD | O |
| UART | O |
This is a GNSS HAT based on MAX-7Q, which supports positioning systems including GPS, GLONASS, QZSS, and SBAS. It features accurate and fast positioning with minor drifting, low power consumption, outstanding ability for anti-spoofing and anti-jamming, and so on. For detailed specifications, refer to MAX-7Q GNSS HAT. |
