Demo Source Code
RPi_demo_#GPIO_basic#_run_on_VisionFive.py:
#import RPi.GPIO as GPIO            # import RPi.GPIO module
#Note: above command must be replaced with command below
import VisionFive.gpio as GPIO      # import VisionFive.gpio module
from time import sleep             # let us have a delay
GPIO.setmode(GPIO.BCM)             # choose BCM or BOARD
GPIO.setup(36, GPIO.OUT)           # set GPIO27 as an output
try:
    while True:
        GPIO.output(36, 1)         # set GPIO27 to 1/GPIO.HIGH/True
        sleep(0.5)                 # wait half a second
        GPIO.output(36, 0)         # set GPIO27 to 0/GPIO.LOW/False
except KeyboardInterrupt:          # trap a CTRL + C keyboard interrupt
    GPIO.cleanup()                 # reset all GPIO ports used by this program
