Running Demo Codes
To run the RPi demo on VisionFive
2, you need to replace the
import RPi.GPIO as GPIOcommand withimport VisionFive.gpio as GPIOin the RPi Python demo. -
Locate to the directory where the test code, #GPIO_basic#_run_on_VisionFive.py, exists:
- Under the sample-code directory, execute the following command to execute the demo code:
sudo python RPi_demo_#GPIO_basic#_run_on_VisionFive.py
sudo python3 RPi_demo_#GPIO_basic#_run_on_VisionFive.py
Result:LED flashes periodically, and you can customize the flashing interval period in the command.
(Optional) Exit the Python3 Virtual Environment.
deactivate
