Boot Flow
This chapter introduces the general boot-up process of the JH-7110 SoC including the image used for boot path, etc.
You can boot from the U-Boot TPL/SPL from StarFive U-Boot, which is the image source code.
The following menu-cascade shows typical JH-7110 boot flow: .
Boot Devices
JH-7110
supports the following boot devices.
- QSPI Flash (For SPL + OpenSBI + U-Boot) + SD Card/eMMC /NVMe (For Kernel + File System and later)
Note: System will detect in sequence whether it can boot
from the following device sequence: . For example, if the boot program is found on the SD, eMMC will
be ignored.
