This document mainly provides the StarFive JH-7110 users and partners with a high-level understanding of how their SoC JH-7110 and single board computer VisionFive 2 are boot up.
| 1.4 | 2024/12/11 | Updated the Boot Process Memory Map. |
| 1.3 | 2023/09/07 | Updated the boot sequence. |
| 1.2 | 2023/07/14 | Since StarFive no longer recommends JH-7110 users to boot directly from SD card and eMMC, removed all the relevant descriptions and updated the boot flow diagram. |
| 1.1.3 | 2023/05/10 | Updated VisionFive 2 Boot Mode Settings. |
| 1.1.2 | 2022/02/02 | Minor change. Corrected a typo in the offset value in Boot Address Allocation. |
| 1.1.1 | 2022/01/19 | Minor change. Removed duplicate sections delivered also in other documents. |
| 1.1 | 2022/01/18 | Refined the boot process and republish. |
| 1.0 | 2022/01/16 | First official release. |
