devm_pinctrl_put
    - Synopsis:
void devm_pinctrl_put(struct pinctrl *p)
 - Description: The interface is equal to the
pinctrl_put()function, but with resource management capabilities. You can deallocate astruct pinctrlobtained viadevm_pinctrl_get().Note: Normally, you may not need this function. Since it may release all resources. - Parameter:
- p: The pin control handle to release.
 - Return: None
Note: The interface can be used only after the devm_pinctrl_get interface has been used. Otherwise, the use is
                invalid.
