pinctrl_get
- Synopsis:
struct pinctrl *pinctrl_get(struct device *dev)
- Description: The interface is used to load the pin operations handle from the device. All operations are based on this pin control handle.
- Parameter:
- dev: The device to which the pin operation applies.
- Return:
- Success: Pinctrl handle.
- Failure: Error code.
