gpio_set_value
- Synopsis:
void gpio_set_value(unsigned gpio, int value)
- Description: The function is used to set the level to a
target GPIO interface. The level can be used to alter the GPIO from an output to
an output. Note: The GPIO has to be an output, otherwise, this function may have no effect.
- Parameter:
- gpio: The GPIO index number.
- value: The expected level: 0 as low level, 1 as high level.
- Return: None.
