of_get_named_gpio
- Synopsis:
int of_get_named_gpio(const struct device_node *np, const char *propname, int index)
- Description: The function is used to obtain a GPIO interface via which you can use the GPIO Application Interface (API).
- Parameter:
- np: Device node to get GPIO from.
- propname: Name of property containing GPIO specifier(s).
- index: Index of the GPIO.
- Return:
- Success: The GPIO index number via which you can use the GPIO API.
- Failure: Error code.
