Using sysfs to Debug
Follow the procedure below to perform the debug.
Enter the /sys/class/gpio/...(sysfs interface) menu.
Figure 1. Using sysfs to Debug
Use the following commands to run the debug.
# cd /sys/class/gpio/ # ls export gpiochipO gpiochip64 unexport # echo 44 > export # ls export gpio44 gpiochipO gpiochip64 unexport # cd gpio44/ # ls active_low direction subsystem value device edge uevent # cat direction in # cat value 1
