SysInstallDeviceLISR Function
It is necessary to provide an implementation of the following
function:
PVRSRV_ERROR SysInstallDeviceLISR(IMG_HANDLE hSysData, IMG_UINT32 ui32IRQ, const IMG_CHAR *pszName, PFN_LISR pfnLISR, void *pvData, IMG_HANDLE *phLISRData)
SysInstallDeviceLISR() is called by the GPU Services server device initialisation code in order to install a device interrupt handling function. Typically, it is sufficient to call the OSInstallSystemLISR() helper function.
