Prepare Hardware
Follow the steps below to prepare hardware for connecting to external codecs.
- Make sure hardware connections are correct.
- Make sure all the hardware connections are correct, including I2C_SDA, I2C_SCK, I2S_MCLK, I2S_BCLK, I2S_LRCK, I2S_DIN, and I2S_DOUT, all the clock and data pins are confirmed as working properly.
- Make sure the I2S module of the SoC and the external codec modules are fed with the proper power supply.
- Make sure you have checked the hardware schematics. And by checking the
schematics, all the following items are correct.
- Confirm that the target I2S and the corresponding pins and pin multiplexing are working properly.
- Confirm that the I2C used for communication between the external codec and SoC is working properly.
- Make sure you have checked the datasheet of the external codec. And by checking
the datasheet, confirm all the following items are correct.
- Confirm the required work mode is master mode or slave mode.
- Confirm that the mclk, sysclk, bclk and lrclk are derived from sysclk.
- Confirm the supported sample rate range.
- Confirm the clock polarity.
- Confirm the data format. (For sample bit width, Left justified, Right justified, I2S, and DSP mode).
- Confirm the I2C address of the external codec.
