Device Driver Configuration
A DTS/DTSI file is used to store all the device tree configuration.
The device tree of Ethernet is stored in the following path:
linux-5.10/arch/riscv/boot/dts/starfive/The following code block shows the DTS file structure for Ethernet.
linux-5.15.0 └-- arch └-- | -- riscv | -- | -- | -- boot | -- | -- | -- | -- dts | -- | -- | -- | -- | -- starfive | -- | -- | -- | -- | -- | -- jh7110-common.dtsi | -- | -- | -- | -- | -- | -- jh7110.dts
The following code block shows an example of the device tree source code of the
"gmac0" in the file jh7110.dts.
gmac0: ethernet@16030000 { compatible = "starfive,dwmac","snps,dwmac-5.10a"; reg = <0x0 0x16030000 0x0 0x10000>; clock-names = "gtx", "tx", "ptp_ref", "stmmaceth", "pclk", "gtxc", "rmii_rtx"; clocks = <&clkgen JH7110_GMAC0_GTXCLK>, <&clkgen JH7110_U0_GMAC5_CLK_TX>, <&clkgen JH7110_GMAC0_PTP>, <&clkgen JH7110_U0_GMAC5_CLK_AHB>, <&clkgen JH7110_U0_GMAC5_CLK_AXI>, <&clkgen JH7110_GMAC0_GTXC>, <&clkgen JH7110_GMAC0_RMII_RTX>; resets = <&rstgen RSTN_U0_DW_GMAC5_AXI64_AHB>, <&rstgen RSTN_U0_DW_GMAC5_AXI64_AXI>; reset-names = "ahb", "stmmaceth"; interrupts = <7>, <6>, <5> ; interrupt-names = "macirq", "eth_wake_irq", "eth_lpi"; max-frame-size = <9000>; phy-mode = "rgmii-id"; snps,multicast-filter-bins = <64>; snps,perfect-filter-entries = <128>; rx-fifo-depth = <2048>; tx-fifo-depth = <2048>; snps,fixed-burst; snps,no-pbl-x8; snps,force_thresh_dma_mode; snps,axi-config = <&stmmac_axi_setup>; snps,tso; snps,en-tx-lpi-clockgating; snps,en-lpi; snps,write-requests = <4>; snps,read-requests = <4>; snps,burst-map = <0x7>; snps,txpbl = <16>; snps,rxpbl = <16>; status = "disabled"; };
The following list provides explanations for the parameters included in the above code block.
- reg: Register base address "0x16030000" and range "0x10000".
- clocks: The clocks used by the Ethernet module.
- clock-names: The names of the above clocks.
- resets: The reset signals used by the Ethernet module.
- reset-names: The names of the above reset signals.
- interrupts: Hardware interrupt ID.
- interrupt-names: The names of the above interrupts.
- phy-mode: The Ethernet PHY mode, for example, "rgmii" or "rmii".
- snps: See Synopsis documentation for PHY specific parameters.
- status: The work status of the Ethernet, "enabled" or "disabled".
"gmac0" in the file
jh7110-common.dtsi:
&gmac0 {
status = "okay";
#address-cells = <1>;
#size-cells = <0>;
phy0: ethernet-phy@0 {
rxc_dly_en = <1>;
rx_delay_sel = <0>;
tx_delay_sel_fe = <5>;
tx_delay_sel = <0xa>;
tx_inverted_10 = <0x1>;
tx_inverted_100 = <0x1>;
tx_inverted_1000 = <0x1>;
&gmac1 {
#size-cells = <0>;
status = "okay";
phy1: ethernet-phy@1 {
tx_delay_sel = <0>;
rxc_dly_en = <0>;
rx_delay_sel = <0>;
tx_inverted_1000 = <0x0>;
};};22 };
The following list provides an explanation of the parameters in the above code block.
- rxc_dly_en: This field is used to set whether to enable the 2ns time delay of the receiver in RGMII mode. 1: Enable. 0: Disable.
- rx_delay_sel: This field is used to configure the receiver clock time delay, 150 ps per step width, accepted range: 0x0 - 0xf.
- tx_delay_sel_fe: This field is used to configure the transmitter clock time delay in 10 M/100 M mode, 150 ps per step width, accepted range: 0x0 - 0xf.
- tx_delay_sel: This field is used to configure the transmitter clock time delay in 1,000 M mode, 150 ps per step width, accepted range: 0x0 - 0xf.
- tx_inverted_10: This field is used to set whether to enable the transmitter clock inversion in 10 M mode. 1: Enable. 0: Disable.
- tx_inverted_100: This field is used to set whether to enable the transmitter clock inversion in 100 M mode. 1: Enable. 0: Disable.
- tx_inverted_1000: This field is used to set whether to enable the transmitter clock inversion in 1,000 M mode. 1: Enable. 0: Disable.
