Kernel Menu Configuration
Follow the steps below to enable GMAC support in the kernel menu dialog.
- Under the root directory of
freelight-u-sdk, type the following command to
enter the kernel menu configuration GUI.
make linux-menuconfig - Enter the Networking support menu.
Figure 1. Networking Support
- Ether the Networking options menu, and in the menu, select
the supported network protocols.
Figure 2. Networking Options
- Enter the Device Drivers menu.
Figure 3. Device Drivers
- Enter the menu and select the GMAC drivers you expect the system to support.
Figure 4. Ethernet Driver Support
- Save your change before you exit the kernel configuration dialog.
