Configuring or Building Buildroot, U-Boot, Linux Kernel, and BusyBox
Use the following commands to configure and build Buildroot, U-Boot, Linux kernel and BusyBox.
Configuring buildroot
Buildroot is a simple, efficient and easy-to-use tool to generate embedded Linux systems through cross complication.
$ make buildroot_initramfs-menuconfig # initramfs menuconfigFigure 1. Example Output
$ make buildroot_rootfs-menuconfig # rootfs menuconfigFigure 2. Example Output
Configuring U-boot
Universal Boot Loader (U-Boot) is an open source, primary boot loader used in embedded devices.
$ make uboot-menuconfig # uboot menuconfig
Configuring Linux Kernel
The Linux kernel is the main component of a Linux Operating System (OS) and is the core interface between a computer's hardware and its processes.
$ make linux-menuconfig # Kernel menuconfig
Configuring BusyBox
BusyBox is a convenient tool-set containing stripped-down versions of many Linux utilities.
- To build menu configuration for BusyBox with the Initramfs file system:
$ make -C ./work/buildroot_initramfs/ O=./work/buildroot_initramfs busybox-menuconfig
Figure 5. Example Output
- To build menu configuration for BusyBox with the Rootfs file system:
$ make -C ./work/buildroot_rootfs/ O=./work/buildroot_rootfs busybox-menuconfig
Figure 6. Example Output
Building Linux Kernel, BusyBox, and FFmpeg
If you want to build single package or module, perform the following commands according to your needs:
To build Linux Kernel:
$ make vmlinux - To build
BusyBox:
make -C ./work/buildroot_rootfs/ O=./work/buildroot_rootfs busybox-rebuild # build busybox package - To build FFmpeg
package:
$ make -C ./work/buildroot_rootfs/ O=./work/buildroot_rootfs ffmpeg-rebuild
