Adding New File
To add new file, perform the following steps:
- Insert the micro-SD card to the PC with Ubuntu system, and execute the
following command to check the SD card
partition:
sudo fdisk -l
Example Output:Device Start End Sectors Size Type /dev/sdc1 4096 8191 4096 2M unknown /dev/sdc2 8192 16383 8192 4M unknown /dev/sdc3 16384 221183 204800 100M EFI System /dev/sdc4 221184 4503518 4282335 2G Linux filesystem
In this output, the
/dev/sdc3
partition is the SD card partition. - Mount the SD card partition under the mnt file
path by
executing:
sudo mount /dev/sdc3 /mnt
Compile the file under the linux directory with the following
command:
make CROSS_COMPILE=riscv64-linux-gnu- ARCH=riscv INSTALL_PATH=<ROOTFS_PATH> zinstall -<jx>
Tip:Result:- <ROOTFS_PATH>: This is a user-defined directory where the vmliunz files will be generated.
- <jx>: It refers to the number of cores in your CPU. If your CPU has 8 cores, change this to -j8.
vmliunz files will be generated under the ROOTFS_PATH.
View the files generated under
${ROOTFS_PATH}
. The following is an example: -
Add the new file:
View the Micro-SD card information.
df -h
Copy the kernel file to the Micro-SD card. Please operate under the path of
${ROOTFS_PATH}.
sudo cp vmlinuz-5.15.0 /media/<User_Name>/root/boot/ && sync
Tip:<User_Name> is your username, for example, atlas.
Copy the modules file to the Micro-SD card. Please operate under the path of
linux/arch/riscv/boot/dts/starfive
.sudo cp jh7110-visionfive-v2.dtb jh7110-visionfive-v2-A11.dtb jh7110-visionfive-v2-ac108.dtb jh7110-visionfive-v2-wm8960.dtb /media/<User_Name>/root/usr/lib/linux-image-5.15.0-starfive/starfive/ && sync
Perform the following step to update the extlinux.conf
file:
cd /mnt/extlinux sudo vim extlinux.conf
Add the following command lines, save and exit:
label <Label > menu label <Menu_Label> linux /boot/<Newly_Complied_Kernel_file> initrd /boot/initrd.img-5.15.0-starfive fdtdir /usr/lib/linux-image-5.15.0-starfive/ append root=/dev/mmcblk1p3 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0
Tip:In these commands:
- <Label>: The label of startup item. For example, l1.
- <Menu_Label>: The configuration name displayed on the menu. For example, myDebian_atlas GNU/Linux-5.15.0-starfive.
<Newly_Complied_Kernel_file>: The vmlinuz file name that is
newly compiled in the previous steps. For example,
vmlinuz-5.15.0 or
Image.gz
Example: The following are the example commands:
label l1 menu label myDebian_atlas GNU/Linux-5.15.0-starfive linux /boot/vmlinuz-5.15.0 initrd /boot/initrd.img-5.15.0-starfive fdtdir /usr/lib/linux-image-5.15.0-starfive/ append root=/dev/mmcblk1p3 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0
(Optional) Load different dtb files:
Execute the following commands to edit uEnv.txt:
cd /mnt sudo vim uEnv.txt
Modify the fdtfile parameter, save and exit:
fdtfile=starfive/<dtb_File_Name>
Note:- <User_Name>: Your user name. For example, atlas.
- <dtb_File_Name>: The dtb files are located in
boot/usr/lib/linux-image-5.15.0-starfive/starfive/ as
shown below:Different boards use different dtb files:Example:
- jh7110-visionfive-v2.dtb: for Version 1.2A and 1.3B board.
- jh7110-visionfive-v2-ac108.dtb: for version 1.2A and 1.3B board with ac108 codec.
- jh7110-visionfive-wm8960.dtb: for Version 1.2A and 1.3B board with wm8960 codec.
Tip: You can refer to the silk print on the board for version information.The following is the example of editing uEnv.txt to load the jh7110-visionfive-v2-wm8960.dtb:
- Unmount the /mnt
directory:
sudo umount /mnt
The following steps are provided to verify if the configuration is successful:
- Pull out the card from the PC and insert it into the VisionFive 2 board. The system will start normally after power-on.
You can find the defined configuration item, for example, myDebian_atlas GNU/Linux-5.15.0-starfive, on the menu, as shown below:
Also, you can see the loaded dtb file, jh7110-visionfive-v2-wm8960.dtb on the startup interface.
After the system starts successfully, you can see the version of the new vmlinuz file:
root@starfive:~# cat /proc/version Linux= version 5.15.0 (atlas@atlas-VirtualBox) (riscv64-linux-ginu-gcc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0, GNU ld (GNU Binutils for Ubuntu) 2.30) #1 SMP Mon Oct 31 15:12:31 CST 2022 root@starfive:~#
