Specifications
VisionFive 2 Lite has the following specifications.
| Type | Item | Description |
| Processor | StarFive JH-7110S | StarFive JH-7110S with RISC-V quad-core CPU with 2 MB L2 cache and a monitor core, supporting RV64GC ISA, working up to 1.25 GHz |
| Imagination GPU | IMGBXE-4-32 MC1 with work frequency up to 400MHz | |
| Memory | 2GB/4GB/8GB | LPDDR4SDRAM, up to 2,800 Mbps |
| Storage | Onboard TF card slot or eMMC | Either the eMMC or the TF card can be chosen. |
| QSPI Flash | The firmware to store U-Boot and BootLoader | |
| Multimedia | Video Output | 1× 2-lane MIPI DSI display port,
supporting up to 1080p@30fps 1× HDMI 2.0, supporting up to 4K@30fps or 2K@60fps |
| Camera | 1× 2-lane MIPI CSI camera port, supporting up to 1080p@30fps | |
| Encoder/Decoder | Video decoder supports up to 4K@60fps and multi-stream for
H264/H265 Video encoder supports up to 1080p@30fps and multi-stream for H265 JEPG encoder/decoder |
| Connectivity | Ethernet | 1× RJ45 Gigabit Ethernet ports |
| USB Host | 3× USB 2.0 and 1× USB 3.0/USB 2.0 ports (multiplexed with a PCIe 2.0 1× lane) | |
| USB Device | 1× USB device port (by reusing the USB-C port) | |
| M.2 Connector | M.2 M-Key, size: 2242 | |
| Wireless | Onboard WiFi 6 & BT 5.4 | |
| Power | USB-C port | USB Type C 5V / 3A |
| GPIO Power In | 5V DC via GPIO header | |
| PoE (Power over Ethernet) | Power function is enabled and requires separate PoE HAT | |
| GPIO | 40-Pin GPIO Header | 1× 40-pin GPIO header, supporting various interface options:
| Button | Boot button | Used for recovering the BootLoader |
| Dimensions | 85 × 56 mm | - |
| Compliance | RoHS, FCC, CE | - |
| Environment | Recommended operating temperature | 0-50 ℃ |
| Other | Debug function | UART TX and UART RX are available through the 40-pin GPIO header |
| Fast boot mode | Used for flashing the OS image to the eMMC Short the J20 header by Jumper and power on, then the board will automatically enter the fastboot mode, the user can flash the OS image to the eMMC via USB-C |
