Hardware Overview
This section provides the hardware overview of VisionFive 2 Lite.
Board Appearance
The following figures illustrate the top and bottom views of the board.
Figure 1. Board Appearance (Top View)
Figure 2. Board Appearance (Bottom View)
See the following table for the board details.
Table 1. Board Appearance Description
No. Description No. Description
1 StarFive JH-7110S with RISC-V quad-core CPU, supporting RV64GC ISA 12 2.4G/5.8GHz Antenna Connector
2 PoE Header 13 2-Lane MIPI DSI
3 Fastboot pins1 14 WiFi/BT module
4 2× USB 2.0 Port 15 40-Pin GPIO Header
5 2GB/4GB/8GB LPDDR4 SDRAM 16 QSPI Flash
6 1× USB 3.0 Port and 1×USB 2.0 Port 17 EEPROM
7 1× Ethernet Port (RJ45) 18 PMIC
8 Recovery Button 19 TF card slot (TF version)
9 2-Lane MIPI CSI 20 M.2 M key
10 HDMI 2.0 Port 21 Onboard eMMC (eMMC version)
11 USB Type C 22 USB2.0 Hub FE1.1S
- - 23 GMAC0 PHY
Pinout Diagram
The following is the pinout diagram:
Figure 3. Pinout Diagram
Note:
  • Each GPIO pin can safely draw a maximum current of 32 mA, whereas the maximum current draw when all GPIOs are combined should be less than 100 mA. Please take this into account or otherwise, you will end up destroying the GPIO pins.
  • All GPIOs can be configured to support different functions including but not limited to SDIO, Audio, SPI, I2C, UART, and PWM. Since VisionFive 2 Lite uses the same GPIO header as VisionFive 2, refer to the VisionFive 2 40-Pin GPIO Header User Guide for GPIO configuration.
1 Short these pins before powering on the board to force entry to the U-Boot Fastboot mode on startup.
