Debug Display
Follow the steps below to debug the display functions for your JH7110.
  1. Follow the steps in Test Case Configuration to configure the test environment.
    Note: Make sure you have configured libdrm and modetest before compiling and burning an image.
  2. After you have completed the kernel start-up, use the following command to verify the display functions and connection status.
    modetest -M starfive
    The following legends and tables display an example output and descriptions.
    • Debug output 1:
      Figure 1. Debug Display 1
      Table 1. Debug Display 1
      Legend Label Description
      possible crtcs Available Cathode Ray Tube Controller (CRTC) devices
      status Whether the display connector is connected or not
      name The name (type) of the display connector
      encoders The connected encoders
      modes The supported display modes
      value The Extended Display Identification Data (EDID) of the screen
    • Debug output 2:
      Figure 2. Debug Display 2
      Table 2. Debug Display 2
      id The CRTC 0x00000001 mentioned in row ① of table Debug Display 1, which means the CRTC is available for use.
      id The CRTC 0x00000002 mentioned in row ① of table Debug Display 1, which means the CRTC is available for use.
      Note: If the displayed CRTC is 0x00000003, both of the CRTCs are available for use.
    • Debug output 3:
      Figure 3. Debug Display 3
      Table 3. Debug Display 3
      Legend Description
      The CRTC and its connected plane
