Sensor Function
The following code block shows the data structure for the sensor function structure.
typedef struct _SENSOR_FUNCS {
STF_S8 (*GetModeIdx)(SENSOR_HANDLE *pstHandle, STF_U16 u16Width, STF_U16 u16Height);
STF_RESULT (*GetMode)(SENSOR_HANDLE *pstHandle, STF_U8 u8ModeIdx, SENSOR_MODE *pstModes);
STF_RESULT (*GetState)(SENSOR_HANDLE *pstHandle, SENSOR_STATUS *pstStatus);
STF_RESULT (*GetInterfaceInfo)(SENSOR_HANDLE *pstHandle, SENSOR_INTFC *pstInterface);
STF_RESULT (*SetMode)(SENSOR_HANDLE *pstHandle, STF_U8 u8ModeIdx, STF_U8 u8Flipping);
STF_RESULT (*Enable)(SENSOR_HANDLE *pstHandle);
STF_RESULT (*Disable)(SENSOR_HANDLE *pstHandle);
STF_RESULT (*Destroy)(SENSOR_HANDLE *pstHandle);
STF_RESULT (*GetInfo)(SENSOR_HANDLE *pstHandle, SENSOR_INFO *pstInfo);
STF_RESULT (*GetRegister)(SENSOR_HANDLE *pstHandle, STF_U16 u16RegAddr, STF_U16 *pu16RegVal, STF_U8 u8Context);
STF_RESULT (*SetRegister)(SENSOR_HANDLE *pstHandle, STF_U16 u16RegAddr, STF_U16 u16RegVal, STF_U8 u8Context);
STF_RESULT (*GetGainRange)(SENSOR_HANDLE *pstHandle, STF_DOUBLE *pdMin, STF_DOUBLE *pdMax, STF_U8 *pu8Contexts );
STF_RESULT (*GetCurrentGain)(SENSOR_HANDLE *pstHandle, STF_DOUBLE *pdCurrentGain, STF_U8 u8Context);
STF_RESULT (*SetGain)(SENSOR_HANDLE *pstHandle, STF_DOUBLE dGain, STF_U8 u8Context);
STF_RESULT (*GetExposureRange)(SENSOR_HANDLE *pstHandle, STF_U32 *pu32Min, STF_U32 *pu32Max, STF_U8 *pu8Contexts);
STF_RESULT (*GetExposure)(SENSOR_HANDLE *pstHandle, STF_U32 *pu32Exposure, STF_U8 u8Context);
STF_RESULT (*SetExposure)(SENSOR_HANDLE *pstHandle, STF_U32 u32Exposure, STF_U8 u8Context);
STF_RESULT (*GetFocusRange)(SENSOR_HANDLE *pstHandle, STF_U16 *pu16Min, STF_U16 *pu16Max);
STF_RESULT (*GetCurrentFocus)( SENSOR_HANDLE *pstHandle, STF_U16 *pu16CurrentFocus);
STF_RESULT (*SetFocus)(SENSOR_HANDLE *pstHandle, STF_U16 u16Focus);
STF_RESULT (*ConfigureFlash)(SENSOR_HANDLE *pstHandle, STF_BOOL8 bAlwaysOn, STF_S16 s16FrameDelay, STF_S16 s16Frames, STF_U16 u16FlashPulseWidth);
STF_RESULT (*Insert)(SENSOR_HANDLE *pstHandle);
STF_RESULT (*WaitProcessed)(SENSOR_HANDLE *pstHandle);
STF_RESULT (*SetFlipMirror)(SENSOR_HANDLE *pstHandle, STF_U8 u8Flag);
STF_RESULT (*GetFixedFPS)(SENSOR_HANDLE *pstHandle, STF_U16 *py16Fixed);
STF_RESULT (*SetFPS)(SENSOR_HANDLE *pstHandle, STF_DOUBLE dFps);
STF_RESULT (*SetExposureAndGain)(SENSOR_HANDLE *pstHandle, STF_U32 u32Exposure, STF_DOUBLE dGain, STF_U8 u8Context);
STF_RESULT (*SetResolution)(SENSOR_HANDLE *pstHandle, STF_U16 u16ImgW, STF_U16 U16ImgH);
STF_RESULT (*GetSnapRes)(SENSOR_HANDLE *pstHandle, ST_RES_LIST *pstReslist);
STF_RESULT (*Reset)(SENSOR_HANDLE *pstHandle);
} SENSOR_FUNCS, *PSENSOR_FUNCS;
| Field | Description |
| *GetModeIdx | Get the sensor mode index |
| *GetMode | Fill in a structure detailing the modes supported by the sensor |
| *GetState | Get the current state of the sensor |
| *GetInterfaceInfo | Get the sensor's connection data bus and I2C hardware information |
| *SetMode | Set the sensor mode |
| *Enable | Enable the sensor |
| *Disable | Disable the sensor |
| *Destroy | Release and de-initialize the sensor |
| *GetInfo | Get information about the sensor |
| *GetRegister | Read the sensor register value |
| *SetRegister | Set the sensor register value |
| *GetGainRange | Get the range of gain settings that the sensor can support |
| *GetCurrentGain | Get the current gain setting from sensor |
| *SetGain | Set the current gain setting to the sensor |
| *GetExposureRange | Get the range of exposures the sensor can use |
| *GetExposure | Query the sensor for the current exposure period |
| *SetExposure | Set the sensor to the requested exposure period |
| *GetFocusRange1 | Get the range of allowed focus positions. No longer in use |
| *GetCurrentFocus1 | Query the current focus position. No longer in use |
| *SetFocus1 | Set the sensor to focus at the selected position. No longer in use |
| *ConfigureFlash1 | Set the sensor to the requested exposure period. No longer in use |
| *Insert1 | Used to control insertion point of the sensor. No longer in use |
| *WaitProcessed1 | Used to wait for an inserted frame to have been fully processed and sent to the ISP. No longer in use |
| *SetFlipMirror | Set flip and mirror value in the sensor |
| *GetFixedFPS | Get the fixed FPS value in the sensor |
| *SetFPS | Set the FPS value in the sensor |
| *SetExposureAndGain | Program the exposure time and gain in the sensor |
| *SetResolution1 | Set the resolution value to the sensor. No longer in use |
| *GetSnapRes1 | Get supported resolution list from the sensor library |
| *Reset | Reset the sensor. |
Note:
The field items are no longer in use.
