Sensor Status
The following code block shows the data structure for the sensor status structure.
typedef struct _SENSOR_STATUS {
    STF_U8 u8CurrentMode;
    STF_U8 u8Flipping;
    STF_DOUBLE dCurrentFps;
    SENSOR_STATE enState;
} SENSOR_STATUS, *PSENSOR_STATUS;
Table 1. Sensor Status Field Description
Field Description
u8CurrentMode Mode ID that the sensor is currently running in, this is an index to the list of modes returned by calling the GetSensorMode function
u8Flipping Select flip and mirror information
dCurrentFps Currently sensor output frame rate
enState Sensor running state
