Sensor Mode
The following code block shows the data structure for the sensor mode structure.
typedef struct _SENSOR_MODE {
STF_U8 u8BitDepth;
STF_U16 u16Width;
STF_U16 u16Height;
STF_DOUBLE dFrameRate;
STF_DOUBLE dPixelRate;
STF_U16 u16HorizontalTotal;
STF_U16 u16VerticalTotal;
STF_U8 u8SupportFlipping;
STF_U32 u32ExposureMin;
STF_U32 u32ExposureMax;
STF_DOUBLE dExposureMin;
STF_U8 u8MipiLanes;
} SENSOR_MODE, *PSENSOR_MODE;
| Field | Description |
| u8BitDepth | The bit depth in the sensor mode |
| u16Width | Width of output in pixels |
| u16Height | Height of output in pixels |
| dFrameRate | Frame rate in Hz |
| dPixelRate | The pixel rate in the sensor mode |
| u16HorizontalTotal | Horizontal total size (including blanking) in pixels |
| u16VerticalTotal | Vertical total size (including blanking) in pixels |
| u8SupportFlipping | Support flipping when enabling |
| u32ExposureMin | Minimum exposure time (integer type) |
| u32ExposureMax | Maximum exposure time |
| dExposureMin | Minimum exposure time (double type) |
| u8MipiLanes | MIPI lanes for MIPI interface sensor |
