pcf8563_irq_enable
- Syntax:
static int pcf8563_irq_enable(struct device *dev, unsigned int enabled)
- Description: The function is used to set interrupt mode of RTC alarm.
- Parameter:
- dev: The target RTC device.
- enable: Interrupt mode.
- Return: None.
