pcf8563_read_block_data
- Syntax:
static int pcf8563_read_block_data(struct i2c_client *client, unsigned char reg,unsigned char length, unsigned char *buf)
- Description: This function is used to communicate between AT8563 RTC and I2C.
- Parameter:
- client: I2C device of the target RTC device.
- reg: Data address.
- length: Data length.
- buf: Read data.
- Return:
- Success: 0.
- Failure: Error code.
