pcf8563_rtc_set_alarm
- Syntax:
Static int pcf8563_rtc_set_alarm(struct device *dev, struct rtc_wkalrm *alarm)
- Description: The function is used to set alarm time on AT8563 RTC device.
- Parameter:
- dev: The target RTC device.
- alarm: The location where RTC time is stored.
- Return:
- Success: 0.
- Failure: Error code.
